ankbhasi Wed, 10/31/2007 - 07:43
  • Cisco Employee,
Hi Friend,
Can you paste the output of "sh interface " on which this pc is connected? Also what is the cable distance from pc to switch?
Ankur
jpannorfi Wed, 10/31/2007 - 07:56
The cable distance is about 100ft.
RD-IDF2-SWITCH1>show int fa0/39
FastEthernet0/39 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0012.4308.eb27 (bia 0012.4308.eb27)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 1y47w, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 32000 bits/sec, 29 packets/sec
5 minute output rate 65000 bits/sec, 43 packets/sec
219928108 packets input, 2426567361 bytes, 0 no buffer
Received 579845 broadcasts (0 multicast)
0 watchdog, 206 multicast, 0 pause input
1387771339 packets output, 2538516768 bytes, 0 underruns
0 output errors, 32881 collisions, 1 interface resets
0 babbles, 0 late collision, 628 deferred
Kevin Dorrell Wed, 10/31/2007 - 08:06
  • Green, 3000 points or more
Sorry, scrap that last conmment - I wrote it before I saw your show int.
The fact is, there is no such thing as a collision in full-duplex. Could this collision count be from a former connection to this port that was operating in half-duplex? Or perhaps with the PC hard-coded and the switchport in auto?
If you clear down the counters now, do the collisions still count up?
Do you have any evidence that the autonegotiation might fail sometimes due to the long cable length. If so, you might do well to hard-code both the PC and the switchport.
Kevin Dorrell
Luxembourg
Kevin Dorrell Wed, 10/31/2007 - 08:01
If the PC is configured 100 full-duplex, adn the switch is in auto, then the switch will actually operate in half duplex, and you will see collisions ... lots and lots of them.
The reason is that if you hard-code the PC into 100-full, then you switch off the negotiation. The switch, not seeing any negotiation, reverts to half-duplex. Result, collisions.
If you hard-code the PC you should hard-code the switchport. If the PC is auto-negotiating, then the switchport should be as well. Do not mix the two.
Kevin Dorrell
Luxembourg
