ASA Management Interface
Answered Question
Oct 31st, 2007
Having read the managment-only command description. It appears that only mangement traffic to the ASA is allowed on this interface (ASDM,Telent,SSH). It can not be used for NTP, SNMP, or logging. Is that correct. Thanks
Correct Answer by JORGE RODRIGUEZ about 9 years 4 months ago
based on documentation the management-only interface will accept incoming traffic only. SNMP , NTP will not work as this will be outbound traffic.. you could convert the dedicated management0/0 port into a routed port by way of licensing for asa5510's and higher.
refer of out-of-band management port bottom of table.
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
rate any helpful posts.
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Thu, 11/01/2007 - 12:54
  • Green, 3000 points or more
Rgds
Jorge
