Two ACS 3.3 Appliances
Oct 31st, 2007
Hi there
I was wondering what you can do with ACS replication between primary and secondary ACS. I want to install two ACS's together with PEAP in a wireless environment. I read on the site that external user database replication is not posible. I want to check the Active Directory for user authentication.
Do i need to configure the two ACS's seperately ?
Gr.
Remco
somishra Wed, 10/31/2007 - 10:22
Hi Remco,
In ACS 3.3 the following items cannot be replicated:
-IP pool definitions
-Cisco Secure ACS certificate and private key files.
-All external user database configurations, including NAC databases.
-Unknown user group mapping configuration.
-User-defined RADIUS dictionaries
-Settings on the ACS Service Management page in the System Configuration section.
-All logging configurations.
-RDBMS Synchronization settings.
Check the following doc about more details on ACS replication:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/3.3/user/guide/sad.html#wp615694
Rgds,
somishra
remco.gussen Thu, 11/01/2007 - 02:24
Thank you for the reply..
Is it posible with the ACS 3.3 appliance and the ACS Windows client, to support authentication in different domains ? Do you have to install the Windows client in the root domain and is authentication / external group mapping possible to the child domain ?
Gr.
Remco
