10-31-2007 10:15 AM - edited 03-03-2019 05:35 AM
Hello all, I am new at configuring routers (just finished CCNA classes) and have had my instructor look over my configuration and even let my instructor take home my router to see that it worked at his home and it does. It seems to be able to connect to the ISP because it does assign it an IP address but I am not able to get on the internet. I will post my config info for evaluation plus other read outs that I have taken. Any help would be great.
11-06-2007 11:55 AM
Type ipconfig on the computer and check if you are getting an ip address and dns server addresses on the computer. Check with yopur ISP if you dont get an ip address or DNS server address. Check if you are able to ping the DNS servers. Check for firewall and antivirus on your computer . Disable them for the time being.
11-06-2007 02:52 PM
Thanks for the reply I didn't think anyone was going to respond. =) I am sorry but I posted a similar link in the "LAN, Switching and Routing:" section of these forums.
Q: Type ipconfig on the computer and check if you are getting an ip address and dns server addresses on the computer
A: I did ipconfig on my workstation and I get proper IP address for LAN (192.168.xxx.xxx) and I get proper DNS address for Verizon. Primary DNS 1: 68.238.64.12 Secondary DNS 2: 68.238.128.12
Q: Check if you are able to ping the DNS servers.
A: I am not able to ping the DNS's from my workstation or the con 0 connection from my server for some reason. But I am able to ping the assigned address to the Routers ADSL WAN connection (71.105.142.101) the Router LAN (192.168.xxx.xxx) and the workstation (192.168.xxx.xxx) from the workstation ethernet or the servers con 0 or ethernet
Note* Server is just local file server not required for internet access.
Q: Check for firewall and antivirus on your computer
A: They are disabled/not Installed. Don't use winxp sp2 firewall and AVG is only antivirus I have but it is disabled/not Installed.
11-14-2007 03:04 PM
irisrios are you still able to assist me? If not can anyone help with this problem?
11-14-2007 03:29 PM
please configure
ip route 0.0.0.0 0.0.0.0 dhcp
also configure
ip domain-lookup
ip dns server
and router's address as dns in dhcp pool.
hope this helps, please rate post if it does!
11-14-2007 04:49 PM
I will try it and let you know thanks.
11-15-2007 12:59 PM
I entered the information you suggested but it is still not working. The following is a copy of the current running config now. I hope they are setup right.
Building configuration...
Current configuration : 1324 bytes
version 12.4
hostname MYHOST
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
logging console informational
no aaa new-model
memory-size iomem 10
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool MYPOOL
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
ip domain lookup source-interface BVI1
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
bridge-group 1
pvc 0/35
encapsulation aal5snap
interface FastEthernet0
ip nat inside
ip virtual-reassembly
speed auto
interface BVI1
mac-address xxxx.xxxx.xxxx
ip address dhcp client-id FastEthernet0
ip nat outside
ip dns server
no ip http server
no ip http secure-server
ip nat inside source list 1 interface BVI1 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
logging synchronous
speed 115200
line aux 0
line vty 0 4
login
end
11-15-2007 01:33 PM
please configure:
interface ATM0
no pvc 0/35
no bridge-group 1
interface ATM0.1 point-to-point
pvc 0/35
bridge-group 1
Then, from router, can you ping 4.2.2.1 ?
11-15-2007 08:05 PM
I appreciate the help. I edited the script as per your instructions and I was not able to connect but, I did notice a difference in the way the ADSL obtained it's address from Verizon. The old configuration I had it was only a second or two before I was able to obtain IP from Verizons network. Once I edited with you suggestions, I obtained an address but it took about 1hr. to an 1 1/2 hrs before I was able to get an IP.
11-23-2007 09:58 AM
Does anyone have any other suggestions that may help??
11-23-2007 10:01 AM
Can you send the revised configuration and output of "show ip int brief" ?
11-23-2007 11:50 AM
I am going to have to hook up the router again to the DSL connection. Upon doing so I will get the info your are requesting but it may take a few hours to get back online seeing as it takes so long for my linksys to pull an ip again after.
11-23-2007 02:06 PM
DSLR#sh ip int brie
ATM0 unassigned YES NVRAM up up
ATM0.1 unassigned YES unset up up
BVI1 unassigned YES DHCP up up
FastEthernet0 192.168.1.1 YES NVRAM up up
NVI0 unassigned NO unset up up
DSLR#
*Mar 5 02:43:15.451: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 71.105.2
25.181, mask 255.255.255.0, hostname DSLR
*UPDATE** I did "sh ip int brie" before the interface got an ip and just after it got assigned an IP as you can see at the end but I was still not able to ping any addresses outside except 71.105.225.181
11-24-2007 12:50 PM
Please configure "ip route 0.0.0.0 0.0.0.0 dhcp".
Failing that, please send config again.
11-24-2007 06:17 PM
DSLR#sh run
Current configuration : 1359 bytes
version 12.4
hostname MYHOST
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp pool MYPOOL
import all
bridge irb
interface ATM0
no ip address
no snmp trap link-status
bridge-group 1
pvc 0/35
ip nat inside
speed auto
interface BVI1
ip nat outside
ip dns server
no ip http server
control-plane
bridge 1 route ip
line con 0
logging synchronous
speed 115200
line aux 0
line vty 0 4
login
end
