no ip address shown on gateway configuration page in ccm
Oct 31st, 2007
Just configured one h323 gateway in CCM 4.23. I can ping the gw from server. But in the ip address field it shows nothing, usually it shows the ip address. This gw is only configured wih incoming dial-peer to receive call from ccm, not dial-peer/destination-pattern/session target pointing to ccm. will it be the reason? As we know H323 is not like mgcp which sends registration packet to ccm. So how does ccm get the ip address? My understanding was once I enter the gw in the CCM, it should auto pop the ip address right below the registration status. thanks
Overall Rating: 4 (2 ratings)
Avner Izhar Thu, 11/01/2007 - 23:16
Just tried it and after adding a gateway nothing happens, but reset to the gateway puts the ip address in there.
HTH, Avner.
gogasca Fri, 11/02/2007 - 00:52
Looks like H225D instance was never created while adding this H323 GW. You may need to restart CCM.exe or look into SDL traces.
