Menu sticking? Cisco 7941 Directory Question
Oct 31st, 2007
We have recently Patched CCM 5.1.2.3000-2 , this version also rolled out a firmware update to the cisco phones.
The annoyance our users are now experiencing is when they press the 'Directories' 'Corp Directory' buttons on the 7941,7911 phones, the menu sticks.
If I was to place a phone call to the searched person, after the call is finished you then have to exit out of 3 menus to get back to the home screen. Can this be configured to automatically go back like the older version?
Brendan
wdrootz Tue, 11/06/2007 - 12:54
This seems to be a new feature. As a workaround you can reduce the idle timer, so that the home screen appears automatically after the specified inactive time.
bmarmont_2 Tue, 11/06/2007 - 13:08
Thanks for that, how does one go about changing the idle timer? This would keep the partners happy. Cheers Brendan
