CallManager Express - FXO disconnect issues
paolo bevilacqua Wed, 10/31/2007 - 16:23
  • Hall of Fame,
    Founding Member
Which exact IOS are using ?
Is this with OPX configured in "connection plar' ?
Disconnect is an issue however it must be not up to the phone that phones keeps ringing forever.
paolo bevilacqua Wed, 10/31/2007 - 16:48
  • Hall of Fame,
    Founding Member
not sure why the low rating. The two questions I asked above are the first to answer to work on the problem, if you expected magic in resolving your problem, that doesn't work with routers sorry.
paolo bevilacqua Wed, 10/31/2007 - 16:53
  • Hall of Fame,
    Founding Member
Ok, without disconnect supervision working you definitely need to configure OPX in as option in 'connection plar".
Not to insist on the rating issue, but the proper 'etiquette' would be to wait until issue is either solved or not before expressing a rating.
paolo bevilacqua Wed, 10/31/2007 - 17:06
  • Hall of Fame,
    Founding Member
Sure.
With connection plar OPX you are OK even with non-functional disconnect supervision, as long you are not using automated services (AA and the like) on the router. But for basic person-to-person calls it will be fine.
