ACS Shell Command Authorization Sets on IOS and ASA/PIX Configuration
I need to activate a control privileges of users on various devices.
I found this interesting document:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
and using a router with IOS 124-11.XV1 work normally while using a switch 2960-24TC with IOS 12.2.25SEE3 not working.
All users (read and full access) access on a not priviledge mode.
WHY?
I have a ACS v3.3 build 2
I have a 2960-24TC with IOS 12.2.25SEE3
I tried with a acs v4.1 without success.
Thanks.
Jagdeep Gambhir Thu, 11/01/2007 - 07:24
Not sure what do you mean by
"All users (read and full access) access on a not priviledge mode.
WHY? "
You mean user are not falling in priv mode ?
~JG
Jagdeep Gambhir Thu, 11/01/2007 - 16:42
If you want user to fall directly in enable mode,then you should have this command,
aaa authorization exec default group tacacs+ if-authenticated
Bring users/groups in at level 15
1. Go to user or group setup in ACS
2. Drop down to "TACACS+ Settings"
3. Place a check in "Shell (Exec)"
4. Place a check in "Privilege level" and enter "15" in the adjacent field
~JG
