Unable to make outbound calls using ISDN BRI
Oct 31st, 2007
Hi guys, I am unable to make outbound calls using CME. I get a busy tone straight away. Inbound works fine. When I debug the error is bearer capabilty not implemented. Any help would be gratly appreciated
paolo bevilacqua Wed, 10/31/2007 - 17:09
  • Hall of Fame,
    Founding Member
Can you post the output of "debug isdn q931' for both incoming and outgoing ?
Unrelated to the problme, if your isdn switch desactivates L1 & L2 on shrt timeout, please configure "isdn tei-negotiation preserve".
This will help speeding up calls.
tony.aleksovski Wed, 10/31/2007 - 17:53
Here is an output of the error. Thanks
Nov 1 00:41:22.534: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 74 c
hanged to down
Nov 1 00:41:22.534: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Nov 1 00:41:26.786: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0
0x0, Calling num 81501909
0x0, Called num 410575095
Nov 1 00:41:26.814: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 74 cha
nged to up
Nov 1 00:41:26.818: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x23
Bearer Capability i = 0x8090
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '81501909'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '410575095'
Sending Complete
Nov 1 00:41:26.986: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA
Cause i = 0x82C131803980 - Bearer capability not implemented
Nov 1 00:41:26.990: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0
Nov 1 00:41:26.994: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0
Nov 1 00:41:32.994: ISDN BR0/1/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Nov 1 00:41:41.978: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 74 c
hanged to down
Nov 1 00:41:41.978: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Nov 1 00:41:47.658: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0
0x0, Called num 0410575095
Nov 1 00:41:47.690: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/1/0, TEI 74 cha
nged to up
Nov 1 00:41:47.694: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x24
Standard = CCITT
Channel ID i = 0x81
Preferred, B1
Called Party Number i = 0x80, '0410575095'
Sending Complete
Nov 1 00:41:47.862: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xA
Nov 1 00:41:47.866: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0
Nov 1 00:41:47.870: ISDN BR0/1/1 Q931: Applying typeplan for sw-type 0x1 is 0x0
Nov 1 00:41:53.870: ISDN BR0/1/1 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Nov 1 00:42:02.830: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/1/0, TEI 74 c
hanged to down
Nov 1 00:42:02.830: ISDN BR0/1/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
