NATing on Source and Destination Address.
Oct 31st, 2007
I have a setup in which the NATing will be done as follows:
Inside Local = 192.168.5.3
Inside Global = 10.150.39.244
Now the requirement is as follows:
When the clients will initiate a traffic the source IP address will be changed to the 10.150.39.244.
Now in my environment there are number of clients those will access the clients on my internal network and they will have the Dest IP address as 10.150.39.244.
Can i achieve the task that the for IP address the Nating is done in both directions?
Mansoor
Anonymous (not verified) Tue, 11/06/2007 - 14:21
When source nating is done the reverse translation is automatically taken care. Meaning when some one access 10.150.39.244
it is automatically translated to 192.168.5.3 . But 192.168.5.3 should have been translated to 10.150.39.244 at least once. This translation should be present in the NAT table of the router.
Mansoor Hafeez Fri, 11/09/2007 - 11:35
My question was that if there is not NAT entry in the router for that IP Address than what will happened?
Will NATing still be performed or Router will drop the packet?
robsinclair Sat, 11/10/2007 - 01:16
I believe that if you have a static nat entry on the router eg ip nat inside source..., then the translation will work in both directions regardless of who starts the conversation.
