10-31-2007 07:24 PM
I am working on my access router for dialup setup. I only wanted to confirm that can we use same IP Pool under different virtual-templates ??
In my setup , I will be having more than 1 tunnels & hence using seprate virtual-template for each tunnel.
config will be like this :
ip local pool VTY_Pool XX.XX.XX.1 XX.XX.XX.254
interface Virtual-Template2
peer default ip address pool VTY_Pool
interface Virtual-Template3
Solved! Go to Solution.
11-01-2007 12:14 AM
This will not be a problem.
You may configure this as proposed.
regards,
Leo
11-01-2007 12:14 AM
regards,
Leo
11-01-2007 02:05 PM
Hi Leo,
Thks 4 ur reply. So it means its IP Pool responsibility to keep track of free ips or allocated ips..
