redistribute connected vs network command under address-family ipv4 vrf
Hi there,
On my implementation, PE-CE link, point to point /30, I configured under address-family redistributed connected.
There is an example I've seen using network command such as below:
address-family ipv4 vrf test
no auto-summary
no synchronization
redistribute static
network 192.168.1.0 mask 255.255.255.252
Is there any major/minor different between those implementation?
Thanks in advance.
Overall Rating: 5 (1 ratings)
kewlnetguy Thu, 11/01/2007 - 03:46
The differnce should be on the ease of extended implementation and the standard followed ( as you seem to be asking from the Service Provider end)
Next time you add another interface, you will have to specify another network command for the /30 IP subnet used for PE - CE link.
Cheers
Prince
shivlu jain Fri, 11/02/2007 - 09:24
  • Silver, 250 points or more
Redistribute connected is used when when we want to redistribute the connected routes and with the help of network command we are using dynaic routing for this.
regards
shivlu
