cisco 1801 router. ISP dns is not working
Oct 31st, 2007
I have a new cisco 1801 router. I have configured the ATM interface to connect to the local ISP. The connection works but for some reason I cannot use the names of the web pages to go into the internet. However I can use their ip addresses to go to the webpages.I have for the time begin turned off the firewall and had a PAT from ATM to VLAN 1.Looks like my connection isnt picking up the ISP DNS. Any assistance would be greatly appreciated
lgijssel Wed, 10/31/2007 - 23:48
  • Red, 2250 points or more
Verify the ip adresses for these DNS servers, they mostly specify two.
Also, there are other dns servers around that might serve your requests, try one of these and see if that helps.
Otherwise, post your config and let us have a look.
regards,
Leo
rodmunch999 Thu, 11/01/2007 - 01:40
As you can see, I have hard coded in the DNS servers in the router but this is not ideal. I am getting dynamic IP address but not the DNS. Below is my config.
!This is the running config of the router: 10.10.10.1
!version 12.4
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp pool sdm-pool
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
dns-server 203.x.x.71 139.130.4.4
lease 0 2
ip domain name yourdomain.com
ip name-server 203.50.2.71
ip name-server 139.130.4.4
ip name-server 139.130.204.47
ip name-server 139.130.4.5
ip ddns update method sdm_ddns1
DDNS both
username admin privilege 15 secret xxx
username 357689 privilege 15 secret xxx
interface FastEthernet0
no ip address
duplex auto
speed auto
interface FastEthernet0.1
description $ETH-LAN$
encapsulation dot1Q 10
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no snmp trap link-status
no cdp enable
interface FastEthernet0.2
encapsulation dot1Q 12
ip address 192.168.12.250 255.255.255.0
ip nat inside
no cdp enable
interface BRI0
no ip address
encapsulation hdlc
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname java.util.regex.Matcher[pattern=[a-zA-Z0-9_+-.]+@[a-zA-Z0-9][w.+-]+.[a-zA-Z]{2,} region=0,3230 lastmatch=[email protected]]
ppp chap password 0 xxxxxx
ppp pap sent-username java.util.regex.Matcher[pattern=[a-zA-Z0-9_+-.]+@[a-zA-Z0-9][w.+-]+.[a-zA-Z]{2,} region=0,3230 lastmatch=[email protected]] password 0 xxxxx
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
access-list 1 remark INSIDE_IF=FastEthernet0.1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^C
cheers
Ravi
lgijssel Thu, 11/01/2007 - 02:22
You are trunking on int fa0. PC hosts will not communicate over a dot1Q trunk. Try this:
ip nat inside
end
modify this acl: access-list 1 permit 192.168.10.0 0.0.0.255
to contain the ip range of your inside network: access-list 1 permit 10.10.10.0 0.0.0.7
With the config as shown, your are not allowing nat for inside hosts on subnet 10.10.10.0
regards,
Leo
andriyhar Thu, 11/01/2007 - 12:56
import all
interface ATM0
no ip address WRONG
negotiated
interface Vlan1
ip nat inside
ip classless
