Replace CCM 5.1 server
Nov 1st, 2007
Hi all,
I have a problem with replacing CCM servers and need your help:
As instructions from Cisco, I'd installed the same CCM version on the new server; backup the old server; turn off the old server, connect the new one to the network and then restore the .tar file to the new server. But after 4 times of trying, the process still failed at the CMDB restore step.
Could anyone give me a suggestion on this and some ideas on replacing the CCM servers!
thanks,
hoanghiep
Jon Nelson Thu, 11/01/2007 - 20:15
  • Silver, 250 points or more
Make sure that you are using the same server name and IP settings as the previous server.
If these are ok, I would gather the backup log files and open a TAC case.
Thank you,
Jon
