Backup the IOS
Nov 1st, 2007
I want to backup IOS from 6509E switch, can anyone tell me how to back up the ios. I have tried with various options like copy disk0:iosname tftp, copy bootflash:iosname tftp but it is saying no file found. please help me.
Overall Rating: 4 (1 ratings)
Jon Marshall Thu, 11/01/2007 - 03:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
SZ-JFH-F00-DTE1#dir
Directory of disk0:/
1 -rw- 74259428 Aug 15 2005 16:39:24 +01:00 s72033-entservicesk9_wan-mz.122-18.SXE2.bin
2 -rw- 5865984 Sep 7 2005 13:46:16 +01:00 c6svc-fwm-k9.2-3-2.bin
3 -rw- 9801676 Sep 30 2005 09:28:26 +01:00 c6slb-csms-k9y9.2-1-1.bin
128055296 bytes total (38125568 bytes free)
SZ-JFH-F00-DTE1#
copy disk0:s72033-entservicesk9_wan-mz.122-18.SXE2.bin tftp
That should do it but it does sound like this is what you have tried.
Where are you tftp'ing to and what type of tftp server is it.
Jon
psureshrao Fri, 11/02/2007 - 05:16
Hi john,
thanx for your reply. Actually the error is, when i try with copy disk0:IOSname tftp: it is copying the file upto 33553920bytes after that it is showing the error
"%Error writing tftp://172.19.X.X/IOSname.bin ....."
I checked the space availability and tftp settings. but nothing helped me.
Jon Marshall Fri, 11/02/2007 - 06:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay, this could be the tftp server you are using as some do have problems with large files.
I use tftpd32 and it works fine. Attached is a link in case you want to try it.
http://tftpd32.jounin.net/tftpd32_download.html
Jon
