same-security-traffic command queries
Answered Question
Nov 1st, 2007
Dear experts,
I wonder if putting in the "same-security-traffic permit intra-interface" or "same-security-traffic permit inter-interface" global commands will make the traffic 'bypass' the ACL for interfaces with same security level?
Your answer is much appreciated.
Correct Answer by Jon Marshall about 9 years 8 months ago
Glenn
The short answer is yes if there is an access-list on the interface then there must be an entry allowing the traffic for it to be allowed back out.
For more details have a look at this document.
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml#t5
Jon
Overall Rating: 4 (1 ratings)
Jon Marshall Thu, 11/01/2007 - 04:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Glenn
The "same-security-traffic permit inter-interface" command will indeed allow traffic to flow between interfaces without access-lists.
The "same-security-traffic permit intra-interface" allows traffic to exit out on the interface it was received on.
Please see attached doc for more details.
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s1_72.html#wp1289167
Jon
glenn.ong Thu, 11/01/2007 - 05:26
Hi Jon,
Thanks for the speedy response.
For "same-security-traffic permit intra-interface" command, will the originating traffic that exits on the same interface still hit the access-list though?
One of our customers have their VPN and thirparty network coming in on the same interface on a FWSM - obviously for VPN-> third party connections, this command is needed to make it work but the connections have to be enforced by ACL too.
Correct Answer
Jon Marshall Thu, 11/01/2007 - 05:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Glenn
Jon
