exec timeout not working
Nov 1st, 2007
I want my telnet session to time out after 3 minutes. But although I add:
line vty 0 4
exec-timeout 3 0
login authentication local_auth
line vty 5 15
exec-timeout 3 0
The telnet session remains on. Not sure why it does this. What am i doing wrong?
onita Thu, 11/01/2007 - 06:34
Could it be that your telnet client sends an anti-idle string.
onita Thu, 11/01/2007 - 12:19
does your running configuration list
service tcp-keepalives-in
glen.grant Thu, 11/01/2007 - 16:45
Try exec-timeout 3 . Doesn't look right the way you have it , not sure what the extra 0 is for .
Richard Burts Fri, 11/02/2007 - 11:12
Glen
The extra 0 is there because you can configure the exec-timeout with minutes and seconds. So the 0 is for 0 seconds.
Shir
I am puzzled why the exec-timeout seems to not be working. The config looks correct. Can you do a telnet that does not timeout after 3 minutes of inactivity, do a show user to verify which line you are connected to, and do a show line for that line and then post these outputs? That might give us a clue as to what is going on.
Rick
himanshu.bansal22 Wed, 04/03/2013 - 23:47
Hi Shir,
I have noticed the same bahviour in my routers also where is set timeout for 30 mins but even then, the sessions are found to be in idle state for a day also.
I am not able to undertand that why it behaving like this.
Did you get the answer to your concern? Please share.
HB
ipec_himanshu Thu, 04/04/2013 - 08:01
Hi Blau,
Accept my sincere thanks for your prompt reply.
I checked the thread but this is not exactly matching my issue.
HB
