Error on E1 PA when enabling E1 controller
Nov 1st, 2007
Hi Guys,
I have come accross the following error a couple of times when dealing with PA-MC-8E1/120) Port adaptors.
xx-RTR01(config)#controller E1 2/6
XX-RTR01(config-controller)# channel-group 0 unframed
%Insufficient HDLC resources to create channel group
I have been unable to find out what this error actually means however, my work around has been to unplug and plug back the port adaptor when I receive the error. It has been successfull most of the time.
Can someone please shed some light?
Thanks and appreciate your response
Paolo Bevilacqua Thu, 11/01/2007 - 08:32
Which exact IOS are you using? This appears like a bug that may have been fixed at some point.
clarence.anslem Thu, 11/01/2007 - 20:19
Sorry missed including the IOS ver.
Im using c7200-p-mz.124-12a.bin
Clarence Anslem
Paolo Bevilacqua Fri, 11/02/2007 - 06:22
As mentioned this can be a bug, if you upgrade to latest 12.4 that is (17) now, and still happening, you need to work with the TAC to be recreated and a bug filed as necessary.
