Second ACS Server
Nov 1st, 2007
We have one ACS server on the network and we need to add a second server. The secondary server will be replicating the primary.
Is it advisable to point some devices to the primary and the other half to the secondary server to balance the load?
JT
Overall Rating: 3 (1 ratings)
Jagdeep Gambhir Thu, 11/01/2007 - 09:20
JT,
Yes, that is a good move here. It will load balance request and response time will be low.
Will recommend to go for it.
~JG
Do rate helpful posts
johnmapa22 Thu, 11/01/2007 - 09:46
Thank you for the response.
I know the secondary server replicates the primary and NOT vice-versa, so does this mean we have to set up all the device groups ONLY on the Primary but point some of the devices to look at the Secondary server first?
JT
Jagdeep Gambhir Thu, 11/01/2007 - 09:51
Yes,
ACS replication is one way only, so you need to be bit careful. When ever there is any change in the primary immediately initiate replication.
~JG
