Which image can give me 'dot1q' and BGP? 2621XM.
Nov 1st, 2007
Darn. I have a 64D/16F 2621XM router. I downloaded BGP compatibel image OK, but now I see that the 'encapsulation' command is not part of the imagine.
Anyone there can suggest which feature I should look for if I want the 'encapsulation' capability? If someone can suggest an image which can do BGP and VLAN support for this old 2621XM, I'd appreciate that. Thanks!
labrouter(config-subif)#encap ?
% Unrecognized command
(by entering
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(24), RELEASE SOFTWARE (fc4) service-policy Configure QoS Service Policy
Technical Support: http://www.cisco.com/techsupport Shutdown the selected interface
Copyright (c) 1986-2007 by cisco Systems, Inc.apshot Configure snapshot suppo
Compiled Thu 18-Oct-07 14:26 by stshen
Image text-base: 0x80008098, data-base: 0x80CEFFA0nterface par
labrouter uptime is 17 hours, 19 minutes
System returned to ROM by reload
System image file is "flash:c2600-i-mz.123-24.bin
JORGE RODRIGUEZ Thu, 11/01/2007 - 09:36
Marlon, visit this link:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
1- Search by feature then look for these and add to selected feature window.
a-IEEE 802.1Q vlan Trunking
b- BGP 4
2- continue to select your platform 2621XM
you should be good with IP BASE image, make
sure you have mininum 64 DRAM memory and 16 megs FLASH.
Jorge
