rwamstutz Mon, 11/05/2007 - 05:34
Thank you. How do I edit the ringlist.xml file in CM 5.1? I found the TFTP upload page and uploaded the loud ring tones, now I need to edit the ringlist.xml file.
Your help is appreciated.
rwamstutz Mon, 11/05/2007 - 08:15
All, I found these commands, but I am having a hard time finding the ringlist.xml file. Can anyone advise how I can find, open and edit this file?
allan.thomas Mon, 11/05/2007 - 17:43
  • Blue, 1500 points or more
The Ringlist.xml file can be uploaded from the CLI by entering the following command:-
file get tftp Ringlist.xml
You will then be prompted for the SFTP server details for where the file is to be downloaded.
Allan.
Pls rate helpful posts.
rwamstutz Tue, 11/06/2007 - 04:40
How can I download from the CLI. I want to open, modify the current ringlist.xml file. I want to see what it is now, so i dont upload and over-write that file with my new file.
allan.thomas Tue, 11/06/2007 - 06:24
If your concerned about over-writing, the you can simply view the file from the CLI and copy the output.
Run the following command from the CLI:-
'file view tftp Ringlist.xml'
Select n to page down, through the file and then q to quit once you reach the end of the file.
Allan.
HTH.
rwamstutz Tue, 11/06/2007 - 06:52
ok, I found it and can view it, how do I edit, it? how do i copy it?
