Configuring a 2800 router for two ISP's
Nov 1st, 2007
How do I configure a 2800 series router for dual WAN connections. I just added another fast ethernet card to the router, and will be connecting two ISP's to the same router. Will need to load balance and set static routes. Anyone know of a knowledgebase article or website that will help me with that?
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Thu, 11/01/2007 - 14:43
what is your topology? assuming you have switch-->2800-->ISP
This could be one way :
interface serial0/0
Description ISP1
ip address
ip nat outside
interface serial0/1
Description ISP2
ip address
ip nat outside
interface fE0/0
ip add
ip nat inside
interface fe0/1
ip add
ip nat inside
ip nat pool ISP1 netmask
ip nat pool ISP2 netmask
ip nat inside source route-map ISP1 pool ISP1 overload
ip nat inside source route-map ISP2 pool ISP2 overload
ip access-list 101 permit
ip access-list 102 permit
route-map ISP1
match ip address 101
match interface S0/0
route-map ISP2
match ip address 102
match interface S0/1
ip route
ip route
there are some other examples here
some threads here
You may also need these resources
NAT support page
if not firewalls between 2800 router and ISP I would recommend go over these acls
kltconsulting Thu, 11/01/2007 - 14:50
Excellent! This info is a big help. Currently, the 2800 router goes straight into a stack of 3 catalyst 2950's. The reason for this dual WAN is there are several users utilizing an imaging database out of Houston that requires a ton of dedicated badwidth. I'd like to static all traffic to that Houston database thru one ISP, and then push all the other traffic (basic internet, email, etc)thru the other ISP. The Cisco rep that sold me the card made mention that 2 VLAN's would have to be created to accomplish this. Wasn't sure what she meant and wanted to see some sample config's.
JORGE RODRIGUEZ Thu, 11/01/2007 - 15:09
You could also do it with one FE interface only by 802.1q trunking FE0 interface to switch and pass two subnets into switch. On switch trunk the port connecting to FE these way you can assign switch ports to be in vlan 2 or 3 for hosts that will go to ISP1
and ISP2 respectivately.
interface FastEthernet0/0
description MyOnlyOne FE INterface
no ip address
no ip proxy-arp
duplex full
speed 100
interface FastEthernet0/0.2
Description VLAN2
encapsulation dot1Q 2 ( for vlan 2 on switch )
ip address
ip nat inside
interface FastEthernet0/0.3
Description VLAN3
encapsulation dot1Q 3 ( for vlan 3 on switch )
ip address
ip nat inside
