htarra Tue, 11/06/2007 - 15:09
  • Bronze, 100 points or more
I think you have to use the trunk protocol ISL and also you have to disabled the trunk and tried to set up an ethernet connection . Use the another available port and cross the fx links and connect it to another switch this way the link should come up.
The following URL will help you:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/dot1qtnl.html
Hi Onur,
I have 7800 Alcatels. When you say not functioning properly, do you have no connectivity? What tagging are you using?
My Alcatel,
wdh-mdf1-swi-f> show vlan 1063
Name : SFarm 10.92.63.0/24,
Administrative State: enabled,
Operational State : enabled,
1x1 Spanning Tree State : enabled,
Flat Spanning Tree State : enabled,
Authentication : disabled,
IP Router Port : on,
IPX Router Port : none,
wdh-mdf1-swi-f> show 802.1q 9/11
Acceptable Frame Type : Any Frame Type
Force Tag Internal : on
Tagged VLANS Internal Description
9 TAG PORT 9/11 VLAN 9
1063 TAG PORT 9/11 VLAN 1063
1069 TAG PORT 9/11 VLAN 1069
1070 TAG PORT 9/11 VLAN 1070
1071 TAG PORT 9/11 VLAN 1071
Cisco side.
VLAN1063
Spanning tree enabled protocol rstp
Root ID Priority 33831
Address 001b.0d5c.3a80
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 33831 (priority 32768 sys-id-ext 1063)
Aging Time 300
Nothing special in the config.
Fred
