11-01-2007 09:04 PM - edited 03-03-2019 05:38 AM
Reply from 10.10.10.14: bytes=32 time=20ms TTL=123
The above reply is got while we tried to ping one of our server i would like to know the what it define of time=20ms and
TTL=123
can u explain the above point and let me know what must be the time difference for good connectivity
regards,
Vinoth
Solved! Go to Solution.
11-01-2007 10:41 PM
As the PING communication packet travels across the network, whenever the packet passes through a router or other network device, TTL (time to live) decreases by one. it is possible, in the most severe cases, for the TTL to drop to a value of zero and then the packet is discarded by the router. In most cases, you can see that the TTL information can be used to determine approximately how many router hops the packet has gone through. TTL does not count the same device twice in standard traffic flow.
The third thing the PING utility provides is the number of milliseconds it takes to get a reply. what this actually represents is an indication of the round-trip time to get a packet to/from the remote device. Again, the response is shownin milliseconds.
11-02-2007 05:19 AM
It is generally a factor of speed & load on link. For LAN it is <10ms, for WAN varies from 30ms to 65ms, & some mpls networks it is 165ms.
I read somewhere, a response time of <200ms is considered to be good.
11-01-2007 10:41 PM
11-02-2007 04:28 AM
Thanks for the reply
I would like to know the average millisecond for the good connectivity
since we are getting the 20 to 30 millisecond when we pinging to some server
Vinoth kumar
11-02-2007 05:19 AM
