Console password is gone
Answered Question
All of sudden, my console password is gone.
When the router says..."Cisco2651XM con0 is now available, Press RETURN to get started."
When I hit return it does not prompt me for the console password and yet in my config, the console password is there.
It used to worked. Any ideas? Thanks
Correct Answer by Edison Ortiz about 9 years 2 months ago
aaa new-model takes over any line authentication and relies on local username authentication (when configured).
Did you enable aaa new-model ?
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Sat, 11/03/2007 - 08:16
amolwaghmare Sat, 11/03/2007 - 10:15
Do you meant to say that if i configured console login name and password and username and password for local login through vty then aaa new-model will force to take username and password configured for vty to gain access ?
Edison Ortiz Sat, 11/03/2007 - 11:47
Once you enable aaa new-model, the authentication prompt changes from
Password:
to
Username: and Password:
If you haven't configured an username and password,
(username [username] privilege 15 password [password])
guess what ? You get locked out.
