Frame-Relay CIR,bc & be Configurations
Nov 1st, 2007
If a customer has subscribed for a CIR of 256 Kbps and a burst of 16 Kbps , what are the Values that i shall set for
frame-relay cir , frame-relay bc , frame-relay be and frame-relay mincir in map-class frame-relay.
are there any specific Ratios (comparing with cir given)for bc and be that we need to set.
susheel.p Wed, 11/14/2007 - 21:32
Sir,
I read the PDF available on this site.but still one doubt i have.Customer has subscribed for access-rate of 64 Kbps and Burst of 16 Kbps.
If i set CIR of 64 Kbps , bc of 8 Kbps , what is the value that i shall set for be. is it 16 Kbps or 2 Kbps so that when multiplied by the Multiplication Value bet. CIR & bc which is 8 here , then it becomes 16 Kbps total.
can you please suggest the value that i shall set for be.
Edison Ortiz Thu, 11/15/2007 - 07:42
  • Hall of Fame,
    Founding Member
You don't necessarily need to set a value for be if the telco hasn't provided. From your post, they've only provided the bc.
Your bc value should be 16000
susheel.p Fri, 11/16/2007 - 02:44
i am on the Service Provider side i:e i have to set be value on my router interface for the customer,so what value for be shall i set in the map-class.
susheel.p Wed, 11/21/2007 - 03:18
