ip communicator 2.1(2)---> Communicator - exception error
Nov 1st, 2007
dear sir,
We've install ip communicator 2.1(2) into iptel environment. We got 1 publisher and 2 subsriber with ccm version 4.1(3)sr5d in a cluster environment. Our problems is everytime we double click the ip communicator to start the ip communicator application, it will prompt with "Communicator-Exception Error" , the error message is : "Unable to initialize support for Cisco Emergency Responder service" . Attached is the screenshot. Please share any idea with this issue? Thank you very much.
-regards-
Overall Rating: 5 (1 ratings)
rob.huffman Sat, 11/03/2007 - 18:46
Hi Charles,
Hope all is well with you :) It looks like you are hitting this bug.
CSCsh89047 Bug Details
VISTA: Unable to initialize support for Cisco Emergency Responder
Symptom:
When loading CIPC 2.1.0.89 on Vista Enterprise error occurrs: 'Unable to initialize support for Cisco Emergency Responder. Please consult your system administrator'
CIPC doesn't load - it hangs in blue screen.
Vista Enterprise is installed on Vista enabled laptop (HP Compaq nx7400, 1GB RAM, 1.83GHZ). Vista is licensed. Tested with CCM 6.0.0.9901-109 and 5.0.3.9911-68
Conditions:
n/a
Workaround:
n/a
Further Problem Description:
n/a
Hope this helps! Sorry, there is no workaround.
Rob
