guruprasadr Fri, 11/02/2007 - 00:25
  • Gold, 750 points or more
Hello Vaibhav, [Pls Rate if HELPS]
"show ip accounting" will provide the Src IP, Destination IP , Packets, Bytes transferred.
Enable "ip accounting" on the interface, use ip accounting in interface config mode. To disable use "no" form to this command.
Refer Link below:
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdip.html#wp1018815
In addition, you can Use Netflow / MRTG monitoring Tool to verify the Bandwidth Used over the Link / CPU Load / CRC errors / Line Load on Interface, etc.,
Hope i am informative.
DO RATE if HELPS
Best Regards,
Guru Prasad R
