IVR in Unity Connection 1.2
Nov 2nd, 2007
I want to enable IVR system in Unity Connection 1.2 . We r using CallManager 5.1 and 2800 voice Gateway with E1 termination ,100 DID nos.
Main req. is to enable IVR , so that when a caller press a Key say "1" the call has to reroute to another call centre where calls handled, Other calls handle locally in the same network.
I didn't see any option to reroute calls to external number (say 23456790)
only extension or greetings are seen.
Rob Huffman Fri, 11/02/2007 - 05:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jerome,
You should be able to set an external number instead if an extension. Press 1 - Links to 9 (if 9 is your access #) plus 23456790.
Hope this helps!
Rob
