Cisco 871-K9
Nov 2nd, 2007
I would appreciate if someone could please answer to following question:
What is the speed (MHz) of device Cisco 871-k9?
Thank you, Susanne
Paolo Bevilacqua Fri, 11/02/2007 - 06:26
Cisco does not release CPU and clock information, please use the performance guidelines (attached) to decide if the 871 is enough for you needs or not.
a.cruea1980 Fri, 11/02/2007 - 07:48
Cisco doesn't release the speeds, no. . .
But a quick check on Google when I had an 871 that worked showed that the processor either ran at 166 or 266MHz. I can't remember which.
The ease way you MAY be able to find out is to do a sh ver. . .it'll tell you the processor in the router. You can plug that into a quick Google search and sometimes come up with a number, unless it's a processor specific to Cisco (which, not all are).
Quick search of your processor. But as Paolo said, Cisco doesn't release the specific speed, and Google will sometimes only give a general speed.
sushansson Mon, 11/05/2007 - 03:55
Thank you for your reply and the attached document which will help to determine about what could be the clock speed.
For you others who reads this message: Please be aware that the pps in the performance document is calculated based on cpu load 100% plus the pps is only unidirectional. I recommend a CPU load not higher than 70% and divide the pps with 2 to get bidirectional(duplex).
Thank you,
