UCCX HA - Msde/SqlSrv
Davide Fiumi
I'll install an UCCX 5.0(1) cluster of 2 servers.
Will I have to upgrade from MSDE to SQL Srv?
How can I do it?
Thanks.
Aaron Harrison
Yes - full SQL is a requirement for HA.
Your software media shoud come with a SQL CD (on 4.x it was CD4). You'd select to install SQL during the installation routine, and MSDE would be installed initially. Then at the end you insert the SQL CD to upgrade to full SQL.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Do you know if you can upgrade to SQL once MSDE is installed?
not sure if you need this anymore, but here is a good document
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_160.pdf
