Traffic Shaping on a 4948 ?
Nov 2nd, 2007
Hi All,
Does anyone have a view on the best method for traffic shaping on a 4948.
I have a CE router connected into a carrier cloud at 1000M and am buying a 10M service, carrier uses policing on their PE.
Now, how do I shape down to 10M on a 4948 interface?
If I have 1 meg of voice purchased and nothing else (all other traffic is BE, should I just set the priority queue to shape at 1M and set Queue 1 or whatever I am putting the rest of the BE packets in to shape at 9M?
ie,
interface GigabitEthernet1/4
tx-queue 1
shape 9M bps
tx-queue 3
priority high
shape 1M bps
Or can you do this as a top level interface command?
Many thx indeed,
Ken
royalblues Mon, 11/05/2007 - 01:48
  • Green, 3000 points or more
I think a nested policy would suit your needs
Create a parent policy which shapes all the traffic out of the interface to 10MB.
In the child policy, make sure you have prioritsed the voice as per the requirements
class-map match-all WAN-VOICE
match ip dscp ef
policy-map WAN-parent
class class-default
shape average 10000
service-policy WAN-child
Policy-map WAN-child
class WAN-VOICE
priority 1024
tx-queue 3
On the interface connecting to the CE
interface g 1/4
service-policy output WAN-parent
Narayan
kfarrington Mon, 11/05/2007 - 02:10
Hi Narayan,
Thx for the reply.
The problem is that the 4948 does not support the shape command under a policy-map, and this is where I am becoming a tad confused as to the best way to do it?
If you or anyone else have done this on the 4948 sucessfully, pls let me know,
All the best and kind regards,
Ken
