11-02-2007 06:58 AM - edited 03-09-2019 07:11 PM
hi,
is it possible to create a lan 2 lan vpn with 2 isp router ?:
LAN1---MyrouterCisco--ISProuter--Internet--Isprouter--MyrouterCisco--Lan2
What i have to ask to my isp (what port to redirect?) ?
do i need the isp router to be in bridge mode ?
sorry for my poor english, and sorry if the question was already ask.
THX all for this support.
11-02-2007 07:59 AM
Do you want to create a l2l VPN between your 2 routers ie. MyrouterCisco1 and MyrouterCisco2 ??
If so do these routers have a public IP address on their outside interfaces ?. If they do you should be able to create a l2l VPN without talking to your ISP unless they are blocking traffic on their routers but most ISP's won't do this unless you specifically ask them to.
Jon
11-02-2007 08:04 AM
hi,
first, thx
yes i want to create a vpn between MyrouterCisco1 and MyrouterCisco2, but i have a private IP adresse on the outside interface :c
what can i do ? can you tell me all my solution
11-02-2007 08:35 AM
You need to talk to your ISP and ask if they can port forward
ESP (port 50)
ISAKMP UDP port 500
Nat-traversal - UDP port 4500
Jon
11-06-2007 07:02 AM
hi,
only to thx you :D i rate this post
