LWAPP mode layer 2 over layer 3 link?
Nov 2nd, 2007
Am I right to assume that if you use LWAPP layer 2 between the APs and the WLC, that it wont work over a layer 3 boundary? LWAPP layer 2 uses ethernet frames, not ip packets, to communicate between the AP and the WLC. Is there anyway to get around this or for this to work without using LWAPP layer 3 mode?
Overall Rating: 5 (1 ratings)
jakew Fri, 11/02/2007 - 07:18
  • Silver, 250 points or more
You assume correctly. No, there is no workaround. You should be using L3 LWAPP anyway since we've deprecated L2 LWAPP. Furthermore, the only APs that support L2 LWAPP are the 1000 Series which have been EoL'd.
ericgarnel Fri, 11/02/2007 - 07:20
  • Gold, 750 points or more
Does the layer 3 boundary present a layer 2 boundary as well?
Think in terms of vlans. How would you connect two vlans? a layer 3 device of course! The purpose of a vlan as defined in http://en.wikipedia.org/wiki/Virtual_LAN
A VLAN can be thought of as a broadcast domain that exists within a defined set of switches. Ports on a switch can be grouped into VLANs in order to limit traffic flooding since it is limited to ports belonging to that VLAN and its trunk ports. Any switch port can belong to a VLAN. Packets are forwarded and flooded only to stations in the same VLAN. Each VLAN is a logical network, and packets destined for stations that do not belong to the same VLAN must be forwarded through a routing device.
So, yes, you are correct in your assumptions
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
