Client VPN on 2811
Nov 2nd, 2007
Trying to setup a client VPN. i've used cisco's document on this and have set these up before. The problem is that it is failing Phase 1. I've attached the configuration, and the isakmp debug output as well as the log from the client.
jsivulka Wed, 11/07/2007 - 07:32
was going through the case and last logs sent by you: Hash verification failed... may be configured with invalid group password. This means that a wrong group password has been entered in the profile (where you set the password in the client connection entry).
On router you can check this password in the config:
crypto isakmp client configuration group 3000client
key cisco123
pool ippool
