source TFTP from inside interface on ASA
Nov 2nd, 2007
Is it possible to source a "copy tftp: flash:" command from the inside interface on an ASA?
I have several ASA's in a customer network that are connected back to my own network by a VPN tunnel. I can successfully TFTP files onto other switches on the inside networks behind the ASA's, just not onto the ASA's themselves. From the ASA's, I can only ping my TFTP server across the tunnel if I specify the inside interface - as in "ping inside x.x.x.x". So, is there something similar for the "copy tftp: flash:" command?
Thanks in advance for any thoughts!
didyap Wed, 11/07/2007 - 12:50
  • Silver, 250 points or more
Try using command "configure net tftp_server_address:filename". This command is used to copy a file to the firewall from the network.
