Etherchannel on 3750
Nov 2nd, 2007
I am trying to configure etherchannel between two linux servers and 3750 switch. Linux interfaces are bonded and can ping each other. Both are on same subnet. When I try to send traffic from one server to another I am getting throughput equal to 1 Gig and its never crossing it. Below is my switch config. Please advise if something need to be changed on switch.
interface Port-channel5
switchport access vlan 10
switchport mode access
interface Port-channel6
interface GigabitEthernet1/0/1
speed 1000
duplex full
channel-group 5 mode active
spanning-tree portfast
i
interface GigabitEthernet1/0/6
speed 1000
duplex full
i
interface GigabitEthernet1/0/17
speed 1000
duplex full
channel-group 6 mode active
interface GigabitEthernet1/0/23
speed 1000
duplex full
Thanks in advance.
Meerz
glen.grant Fri, 11/02/2007 - 16:08
  • Purple, 4500 points or more
You have to remember etherchannel is a load balancer not specifically an aggregator . If you have a specific conversation between 2 devices it is always going to go down the same link , it does not go down both ports . this is a way it works with the etherchannel hashing algorithom cisco uses. So a specific conversation in a etherchannel has a 1 gig pipe and thats it . A different conversation may go down the other side but that will also only have a gig to play with .
