Warning message
etienne.basset Wed, 11/07/2007 - 08:50
hello
configure one primary te tunnel D=>A given explicit path, tunnel FRR protected
configure a te tunnel D => A given explicit path DBCA
configure the backup tunnel on interface D=>A
Etienne
kewlnetguy Thu, 11/08/2007 - 23:48
Your intention is to pass traffic between A and D, and want to reroute the traffic via B and C node.
As FRR uses the tunnel in between to tunnel tail , i say if you create two tunnels between A and D as following :
Tunnel 1 : A to D explicit path A - D
Tunnel 2 : A to D explicit path A -C-B -D
and prioritise the tunnel 1, you should achieve the required.
Also note TE tunnels are unidirectional so create resiprocal tunnels for traffic from D to A
Cheers
Prince!
