11-02-2007 09:21 AM - edited 03-03-2019 07:23 PM
We are about to implement QOS on our WAN and are considering upgrading our older routers to the 1841 model. The current routers run the ipbase image but my supplier says that an 1841 with ipbase does not support some QOS functionality. What is the minimum image required to support all QOS features on an 1841?
Michael
Solved! Go to Solution.
11-06-2007 09:42 AM
Hi, as Arul said, you will be Ok with the 1841, even with the IP base image.
If you can wait for the distributors to receive stock, you can look at the 1861 that supports voice with analog and ISDN interfaces, plus the IP phones as well.
WRT QoS using voice, all what you want is LLQ, that is in all the images.
11-02-2007 10:27 AM
IP Based on 1841 supports the below QOS Features.
QoS Bandwidth Estimation
QoS Device Manager (QDM)
QoS for Virtual Private Networks
QoS Packet Marking
QoS Priority Percentage CLI Support
Quality of Service (QoS) - Classification Only
Quality of Service (QoS) Queuing
Query Mode Definition Per Trustpoint
Query Multiple Servers during Certificate Revocation Check
Is QoS the only feature that is driving you to a different feature set other than the IP Base or are there other requirements. I am curious to know what QoS Feature that the supplier is referring to. Please share if you get this information.
Also, please use the feature navigator to compare images and this should give you a detail list of differences between different images/feature sets.
www.cisco.com/go/fn
Arul
Please rate all helpful posts
11-06-2007 09:12 AM
Thanks for your reply. Sorry, what the supplier actually said was that ipbase supports 'some' QOS functionality, which lead me to wonder what functionality I was missing out on. We are running VOIP between our branches and just want it to work well, everything else is currently being handled with an ipbase image on 1721's.
11-06-2007 09:42 AM
