Warning: Saving this config to nvram
Nov 2nd, 2007
Hello friends!
I need some help with this error...
i am recieving this error:
#copy runn start
Destination filename [startup-config]?
Building configuration...
% Warning: Saving this config to nvram may corrupt any network management or security files stored at the end of nvram.
Continue? [no]:
% Configuration buffer full, can't add command: <private>
%Aborting Save. Compress the config, Save it to flash or Free up space on device[OK]
someone has in experience something like this?
i am now starting to investigate possible solution...
any recomendation?
regards.
Richard Burts Fri, 11/02/2007 - 09:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Fernando
I experienced the message about saving the config may corrupt network management... in a couple of versions of IOS. I have saved the config anyway and not had any problems resulting from that.
Rick
fcmartinez Fri, 11/02/2007 - 10:43
OK mine friend let me check of nothing happend :S
thanks!
