WIC-2T
Nov 2nd, 2007
Is it possible to communicate between two 2600 router using WIC-2T without using CSU/DSU.
When I install WIC-2T I get this error
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate
Wilson Samuel Fri, 11/02/2007 - 10:30
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
If the router doesn't recognise the Card then most probably its the reason because the Router doesnt support that particular WIC model.
Btw, if you want to terminate T1 without any CSU/DSU you should be using WIC 1-T CSU/DSU (it will be clearly imprinted on the WIC) and then you could directly terminate any T1 (or fractional T-1) on the router
Hope this helps.
Kind Regards,
Wilson Samuel
Paolo Bevilacqua Fri, 11/02/2007 - 10:55
  • Hall of Fame,
    Founding Member
Indeed the 2600 supports WIC-2T, so the problem must be something else:
http://cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b0858.shtml
In many cases, the reason for using serial interface rather than T1 or E1, is because in many countries and telcos, is mandatory to use an external DSU with V.35, in addition the circuit is often fractional, etc.
As opposed to the US that is less regulated and native T1 interface is the norm and not the exception.
moazzamkhan Fri, 11/02/2007 - 11:20
Thanks guys for the input.
Actually I am setting up a lab experiment in which I want to connect to routers using DCE/DTE cable with WIC-2T on both routers. Will they work fine if I don't have any CSU/DSU device and with the error message that I am getting
moazzamkhan Fri, 11/02/2007 - 11:25
I am trying to use DCE/DTE cable to connect the two routers having WIC-2T card. Do I have to enable some clocking at the DCE end to get rid of this error message. Can someone give me the commands to enable this clocking.
Wilson Samuel Fri, 11/02/2007 - 11:43
Yes, if you are connecting two serial interfaces back-to-back without any CSU/DSU, you must enable clocking on the DCE interface.
Hope that helps
Kind Regards,
Wilson Samuel
moazzamkhan Fri, 11/02/2007 - 11:53
Thanks Samuel
Can I choose any of the two routers as the DCE and issue command
Router(config)#interface serial0
Router(config-if)#clockrate 56000
I have configured the router fresh. Do I have to do something to make one as DCE.
Wilson Samuel Fri, 11/02/2007 - 11:56
The Serial interface which is connected to a Female Serial Cable is DCE interface and thats it. You need not make any other changes in the router either in H/W nor in the configuration (except ofcourse adding the clockrate command)
Hope this helps
Please rate
wilson Samuel
