cdp on sc0 interface
Nov 2nd, 2007
How can you enable cdp on just the sc0 interface? Our private(management) connection is plugged into the mgmt port on the supervisor. So how do you specify that port, if you can? Thanks.
Edison Ortiz Fri, 11/02/2007 - 14:18
  • Hall of Fame,
    Founding Member
sc0 is a logical interface
Your query is like asking, 'how do I enabled cdp on interface vlan 1'.
CDP is enabled on physical interfaces, by default.
