logging buffered not working
Nov 2nd, 2007
i don't see any events logged to buffer. Can you advise why?
logging buffered 16384 informational
! also tried
! logging buffered 20000 debug
logging [server_ip]
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server host [server_ip] network
snmp-server host [server_ip_1] public
6509_sup_750#conf t
Enter configuration commands, one per line. End with CNTL/Z.
6509_sup_750(config)#int g3/33
6509_sup_750(config-if)#shut
6509_sup_750(config-if)#^Z
6509_sup_750#sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns)
Console logging: level debugging, 125 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: level debugging, 5 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 141 message lines logged
Logging to [server_ip], 141 message lines logged
Log Buffer (20000 bytes):
Nov 2 17:19:34.770: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ([laptop_ip])
Nov 2 17:20:19.954: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ( [laptop_ip])
Nov 2 17:24:08.302: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ([laptop_ip])
Nov 2 17:24:24.142: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ( [laptop_ip])
Nov 2 17:24:38.394: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ([laptop_ip])
6509_sup_750#conf t
6509_sup_750(config-if)#no shut
6509_sup_750#sh log
Console logging: level debugging, 126 messages logged
Buffer logging: level debugging, 6 messages logged
Trap logging: level informational, 142 message lines logged
Logging to [server_ip], 142 message lines logged
Nov 2 17:19:34.770: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ( [laptop_ip])
Nov 2 17:20:19.954: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ([laptop_ip])
Nov 2 17:24:08.302: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ( [laptop_ip])
Nov 2 17:24:24.142: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ([laptop_ip])
Nov 2 17:24:38.394: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ( [laptop_ip])
Nov 2 17:24:50.630: %SYS-5-CONFIG_I: Configured from console by [username] onvty2 ([laptop_ip])
Thanks.
Joe Clarke Fri, 11/02/2007 - 14:17
I don't see the problem. You have five messages logged to the buffer:
What are you expecting to see?
danger_mousie Fri, 11/02/2007 - 14:24
In the example you can see me admin down an interface, this doesn't appear in the logs. Cabling was done today so interfaces and port channels were going up and down but none of that appears in the logs.
Thanks.
danger_mousie Fri, 11/02/2007 - 14:26
141 messages were sent to the server_ip but only 5 appear in the logging buffer
Joe Clarke Fri, 11/02/2007 - 17:17
I missed where you downed an interface in your testing. It would be helpful to see the full show run as well as a show ver from this switch.
danger_mousie Sat, 11/03/2007 - 04:11
Solution:
6509(config)#int range g2/1 - 48
6509(config-if-range)#logging event link
6509(config-if-range)#logging event bundle
6509(config-if-range)#logging event trunk
6509(config-if-range)#logging event spanning-tree status
Nov 3 13:04:09.986: %LINK-5-CHANGED: Interface GigabitEthernet3/33, changed state to administratively down
Nov 3 13:04:09.990: %LINK-SP-5-CHANGED: Interface GigabitEthernet3/33, changed state to administratively down
Nov 3 13:04:12.374: %LINK-3-UPDOWN: Interface GigabitEthernet3/33, changed state to down
Nov 3 13:04:13.006: %SYS-5-CONFIG_I: Configured from console by [username] onvty0 ([laptop_ip])
Nov 3 13:04:12.378: %LINK-SP-3-UPDOWN: Interface GigabitEthernet3/33, changed state to down
