IP Phone is not executing my HTTP redirect
Nov 2nd, 2007
I have developed a Contact Center app running as a XML services on the IP Phone. Sometimes I'm pushing a packet to the phones (7941/61) containing a HTTP Redirect and the phone is not doing the HTTP GET to the redirected URL. It works OK and then stop executing the HTTP redirect without any notice.
Any thoughts?
msabir Fri, 11/02/2007 - 18:49
  • Bronze, 100 points or more
I had problem with redirect as well but it got fixed after trying a different phone load.
patrick.lepage Fri, 11/02/2007 - 18:54
Ok which one you have used. I don't have mine handy at this time but I will cross-ref with your. Just FYI, I'm running CCM 4.1.3 with latest patches.
msabir Mon, 11/05/2007 - 04:59
It is not the CCM version but the phone load that is important.
patrick.lepage Mon, 11/05/2007 - 05:48
I know it was FYI only.
What is the load you used to fix the issue?
msabir Mon, 11/05/2007 - 05:49
I don't have that information handy at this point. I would recommend trying the latest phone load. If you are already on latest, go back 1-2 versions.
