l2tp/ipsec Remote Access Vpn
Nov 3rd, 2007
hi ,
i wanna configure l2tp/ipsec vpn between winXP Client And Pix515e Firewall .
this is my configuration :
PIX Version 7.2(2)
hostname Pix
enable password xxx
names
interface Ethernet0
nameif outside
security-level 0
ip address 172.16.1.254 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet3
shutdown
no nameif
no security-level
no ip address
interface Ethernet4
shutdown
no nameif
no security-level
no ip address
interface Ethernet5
shutdown
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
access-list nonat extended permit ip 192.168.0.0 255.255.255.0 10.20.30.0 255.255.255.0
access-list l2tp extended permit ip host 172.16.1.254 any
pager lines 24
mtu outside 1500
mtu inside 1500
ip local pool mypool 10.20.30.1-10.20.30.100 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
aaa-server radius protocol radius
aaa-server radius host 192.168.0.2
key nasser
group-policy l2tpipsec internal
group-policy l2tpipsec attributes
dns-server value 4.2.2.4 192.9.9.3
vpn-tunnel-protocol l2tp-ipsec
default-domain value NCG
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set l2tp esp-des esp-sha-hmac
crypto ipsec transform-set l2tp mode transport
crypto ipsec security-association lifetime seconds 3600
crypto dynamic-map dyna 20 set transform-set l2tp
crypto map mymap 10 ipsec-isakmp dynamic dyna
crypto map mymap interface outside
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption des
hash md5
group 1
lifetime 86400
tunnel-group l2tpipsec type ipsec-ra
tunnel-group l2tpipsec general-attributes
address-pool mypool
authentication-server-group radius
default-group-policy l2tpipsec
tunnel-group l2tpipsec ipsec-attributes
pre-shared-key nasser
tunnel-group l2tpipsec ppp-attributes
authentication pap
authentication ms-chap-v2
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh timeout 60
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
now when i debug crypto isakmp i get this messages :
Pix(config)# Nov 03 11:40:50 [IKEv1]: Group = 172.16.1.22, IP = 172.16.1.22, Can't find a valid tunnel group, aborting...!
Nov 03 11:40:50 [IKEv1]: Group = 172.16.1.22, IP = 172.16.1.22, Removing peer from peer table failed, no match!
Nov 03 11:40:50 [IKEv1]: Group = 172.16.1.22, IP = 172.16.1.22, Error: Unable to remove PeerTblEntry
Nov 03 11:40:51 [IKEv1]: IP = 172.16.1.22, Header invalid, missing SA payload! (next payload = 4)
Nov 03 11:40:53 [IKEv1]: IP = 172.16.1.22, Header invalid, missing SA payload! (next payload = 4)
and in client side i get error 800 .
please help me .
ivillegas Wed, 11/07/2007 - 14:26
  • Silver, 250 points or more
This error message on the PIX means that the tunnel group for the connection is not configured correctly. Make sure that the tunnel-group name to the ip address of the remote peer.
