Identify devices attached to trunking ports
Answered Question
Nov 3rd, 2007
I have been presented with a question in which I only have a CONSOLE to a switch that is connected to another switch and a router. There are VLANs configured.
What show command in the switch would tell me to which port the ROUTER is connected to? WOuld the "show interfaces trunk" do that? on my lab it tells me the ports that are trunking but it does not specify the devices attached to it
ROUTER======SWITCH W/CONSOLE=====SWITCH
Thanks in advance
Correct Answer by miller811 about 9 years 2 months ago
show cdp neighbor or show cdp neighbor detail should tell you what type of device is connected to your switch and port it is connected to.
Overall Rating: 5 (1 ratings)
Correct Answer
miller811 Sat, 11/03/2007 - 05:26
sciscoforce Sat, 11/03/2007 - 09:57
Thanks miller811! What a piece of cake!
I have used that command on the router but not switches. Newbie after all!
Thanks again and have a nice day
