ACE: Can't allocate resource class due to resource in use
danger_mousie
When I try to enter the member [resource_class] command under the context config mode I get...
Error: resources in use
Any idea how I get around this?
Note: I am trying to do this so that I can configure stickiness in my context and I get
Error: sticky resource not available
6 Replies 6
DJBuechner
The issue you are running into is that you have already allocated all of the sticky database resources. If for example you define a resource-class with a limit-resource command which specifies a minimum of 20% of the sticky database resources then you can only have 5 contexts as members of this resource-class (5 x 20 = 100). You will then get the "resources in use" message when you try to add a sixth context as a member.
This is the first resource class/context relatoionship I have created. There is the default class however, do I need to cut that down? I was planning to divide it between the 5 contexts anyway so 20% is fine. Have I understood correctly?
is this any help?
ace-1/Admin# sh resource usage
Allocation
Resource Current Peak Min Max Denied
Context: Admin
conc-connections 10 11 0 8000000 0
mgmt-connections 4 14 0 5000 0
proxy-connections 0 0 0 1048574 0
xlates 0 0 0 1048574 0
bandwidth 502 93472 0 500000000 410
connection rate 0 40 0 1000000 0
ssl-connections rate 0 0 0 1000 0
mgmt-traffic rate 156 26863 0 125000000 0
mac-miss rate 0 8 0 2000 0
inspect-conn rate 0 0 0 6000 0
acl-memory 6360 6520 0 78610432 0
regexp 0 0 0 1048576 0
syslog buffer 3562496 3562496 0 4194304 0
syslog rate 0 11 0 3000 0
Context: C1
conc-connections 2 8 0 8000000 0
mgmt-connections 22 56 0 5000 0
proxy-connections 0 8 0 1048574 0
bandwidth 276 387123 0 500000000 0
connection rate 2 30 0 1000000 0
mgmt-traffic rate 92 13673 0 125000000 0
mac-miss rate 0 2 0 2000 0
acl-memory 3664 20288 0 78610432 0
syslog buffer 631808 631808 0 4194304 0
syslog rate 2 24 0 3000 0
Context: C2
conc-connections 0 0 0 8000000 0
mgmt-connections 0 0 0 5000 0
bandwidth 0 514 0 500000000 0
connection rate 0 2 0 1000000 0
mgmt-traffic rate 0 390 0 125000000 0
mac-miss rate 0 0 0 2000 0
acl-memory 0 5120 0 78610432 0
syslog buffer 0 0 0 4194304 0
syslog rate 0 0 0 3000 0
I think it is due to the fact that the resources themselves are in use, as the error says, not that they are allocated. How do I get around this, do I have to wipe he config, then create the resource classes? But I don't know what kind of resources are required for each application until SIT testing is done, and for that, I need the config in place.
Could you attach or include your running-config from the Admin context as well as a copy of the output of 'show resource allocation'? These would be most helpful.
- David
It's ok, I have it working now. I had to allocate all the 'not in use' resources individually, this included sticky. So it's fine now. Thanks for your help.
