7911 question
Nov 3rd, 2007
hello
i would like to know if its posible to connect one ip phone on the 10/100 port of another ip phone and it work or we need to do anything special for work that connection.
thanks
Overall Rating: 4 (2 ratings)
Avner Izhar Sat, 11/03/2007 - 10:49
It would probably work if voice and data are on the same vlan. Have done it before with different phone types in shows and short term testing environments.
It is not supported and not recommended for production environments.
HTH, Avner.
rob.huffman Sat, 11/03/2007 - 11:23
Hi Bill,
You will need to remember two things if you daisy-chain IP Phones together. The second phone will need to be powered by a Power Cube and this setting needs to be changed;
Forwarding Delay
Indicates whether the internal switch begins forwarding packets between the PC port and switch (SW) port on your phone when your the PC port becomes active.
Displays Yes or No.
When set to No, the internal switch begins forwarding packets immediately. When set to Yes, the internal switch waits 8 seconds before forwarding packets between the PC Port and the SW Port.
Set the Forwarding Delay to Yes if you connect both ports to switches for redundant uplinks or daisy chain phones together.
Cannot configure locally. Use Cisco CallManager to modify.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_administration_guide_chapter09186a0080080666.html#wp1041991
Hope this helps!
Rob
