11-03-2007 09:01 PM - edited 03-09-2019 07:12 PM
I want to remove 2 entries from a context cfg for an ACL and cannot find a way to do it. Here is the cfg:
access-list PERMIT-PRINT extended permit ip 10.10.50.0 255.255.254.0 165.24.146.90 255.255.255.240
access-list PERMIT-PRINT extended permit ip host 90.132.101.16 host 168.34.266.70
access-list PERMIT-PRINT extended deny ip host 90.132.101.16 host 168.34.266.70
The last 2 lines are the ones and when I do a sh access-list it shows them as line 9 & 10 in sequence.
Thanks for any help.
11-04-2007 06:09 AM
Which version of FWSM software are you using?
11-04-2007 11:24 AM
We are using:
FWSM Firewall Version 3.1(3)
Device Manager Version 5.0(1)F
11-04-2007 12:01 PM
You will be able to delete these entries using keyword "no" in front of them in global configuration mode on the command line
no access-list PERMIT-PRINT extended permit ip host 90.132.101.16 host 168.34.266.70
no access-list PERMIT-PRINT extended deny ip host 90.132.101.16 host 168.34.266.70
11-04-2007 01:38 PM
I tried that and got the following error:
ADC-FW-CORE/3RD-PARTY-VENDORS(config)# no access-list PERMIT-PRINT extended pe$
^6.70
ERROR: % Invalid input detected at '^' marker.
11-04-2007 02:31 PM
This is unusual. I would try a "?" just at the error marker to see what it is expecting.
Other than that another option is to paste the whole access-list into a text document. Do a "clear configure access-list PERMIT-PRINT". The relative access-group statement may also be removed by this. Then paste in the statements you want to keep and reapply the access-group.
However, you may need a service window to do the latter.
11-04-2007 02:49 PM
That is what I thought you may say, and yup in case of service affecting I may have to setup a change window. Thanks for your help.
