How long does it take for LDAP sync in CM6? Solved
Nov 3rd, 2007
DirSync service was not started.
Hi, I'm running cm6 in my vmware machine and have it configured to sync with my test active directory. I can add the ldap directory correctly, but how long does the sync take? My active directory has no more than 20 users in the OU I specify. There is no progress indicator to tell you how the sync process is going. So does anyone have any rough idea how long it takes? I've waited three hours and still cannot locate any end users from the admin page. Also, I did a perform sync once and clicked sync now. Thanks
craiglcve Sun, 11/04/2007 - 09:09
I just did a CM 6 install with AD LDAP integration. When I would add users or make changes to users in AD and go to the LDAP config on CallManager and click on the sychronize button I would see users or the changes to users within a minute or so if that.
